1 members (2-Ton),
167
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | Ok, My 52 got a new gas tank recently. Before it was replaced the gauge in the dash did not work(found out why when i pulled the sending unit-In peices) While tank was out and wiring disconnected the gauge read full with the key turned on for a few days, then the gauge stayed a empty. Replaced the tank and sending unit connected the wires they way the were removed. the gauge still shows empty. I ordered a new gauge but before i install it can anyone help with the wiring? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might get more bites if you put this in the electrical section but then, you might not.. this link might help.. click here
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | | | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | How many wires are to be connected at the sending unit? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | One wire from the gauge. Some people run another ground wire from a sender attachment bolt/screw to any good ground point.
| | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | That is how i have it wired and the gauge does not work correctly. New gauge and sending unit. With the sending unit removed from tank and manually operated the guage goes from the dot closest to the E (im assuming 1/4 tank) to inbetween 1/4 and 1/2 with the float at the full position. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | test it BEFORE you put the sender back in the tank hook up the two wires [gauge & good ground] and actuate the float......... see if your gauge /sender works 1st.
BEST if put this in stovebolt electrical
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
