10 members (Shaffer's1950, Cletus1950, Leo, NAPCOStormTrpr, Otto Skorzeny, GDW, MNSmith, Hanks custodian, Peggy M, Hotrod Lincoln),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,139 Posts1,056,455 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Hi, Anyone find a source for these? It's a 1961 Chevy C30 (1 ton) Panel truck. Need the lower ball joint. Moog # 6015 TRW # 10149 If anyone has the GM part number, I'd like to have that too. Thanks. Pete (who thought 60-66 Chevy trucks were all the same----I was wrong!!) Funny, it looks innocent enough........... http://www.stovebolt.com/gallery/geurds_pete_1961.html | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | NAPA should have them or at least get them. | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | NAPA should have them or at least get them. Hi, NAPA doesn't stock them, GM, TRW, and MOOG don't make them. Closest I've come is Rare Parts ( http://www.rareparts.com/products/) $250 each + $50 core charge. Anyone have any alternatives to swapping the crossmember? Not sure you can even do that to a 60-62 C30, anyone know? I'll have to read through the archives again. Pete | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I can't help on the parts.
I've seen the IFS on a '61 1-ton and it looked very similiar to the later coil spring type. I was curious how different they are so looked it over pretty good, but did not measure it at all. It has since been scrapped.
I've seen at least one thread where someone said they have swapped the torsion bar IFS for a coil spring one, but I haven't done it.
At this very moment I have a '72 C20 IFS on a workbench in my shop. I'll try to measure anything you describe on it. It may be back under the truck soon, so this could be a limited time offer...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | Yes you can swap the whole crossmember from a later coil spring truck. You will need to drill two holes for the idler arm if you go to a 73 up front end. Im shure that you could do the swap much cheaper than what those ball joints would be. OldWolf | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Yes you can swap the whole crossmember from a later coil spring truck. You will need to drill two holes for the idler arm if you go to a 73 up front end. Im shure that you could do the swap much cheaper than what those ball joints would be. OldWolf Old Wolf, Sounds good. But, I thought I had seen in the archives that the 60-62 frames were narrower. Don't know. Measure mine and hit the junk yard I guess. Thanks Pete | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | I myself have installed a 73 crossmember disk brakes the whole shooting match on a 61 chev 1/2. The frames are different in that the torsion bar frames are boxed and have a X member. Also they are different at the rear bumper. but the complete cabs beds and front sheetmetal will all interchange. between 60 and 66 models. the 63 up bumpers wont fit the earlier models. OldWolf | | | | | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | I myself have installed a 73 crossmember disk brakes the whole shooting match on a 61 chev 1/2. The frames are different in that the torsion bar frames are boxed and have a X member. Also they are different at the rear bumper. but the complete cabs beds and front sheetmetal will all interchange. between 60 and 66 models. the 63 up bumpers wont fit the earlier models. OldWolf OldWolf, That's encouraging. I take it you used a 1/2 ton crossmember? Thanks Pete | | | | | Joined: Jun 2009 Posts: 25 Apprentice | | Apprentice Joined: Jun 2009 Posts: 25 | Don't want to hijack your thread but I also have a similar problem and have a 1962 c10 1/2 ton and I was wondering if I could take the front end out of a 78 suburban and put into my 62 so my cross member would have the motor mounts already in them and also for the breaks to be upgraded so does anyone know if this can be done?
Thanks and again sorry to hijack your thread..... | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | Yes it will easily work. like i stated earlier you have to drill two holes for the front idler. also you should get a purporiong valve and the dual master cyl and powerbrake booster. Although the latter is not absoultly necssairy if you have strong leg muscles! OldWolf | | |
