4 members (78buckshot, klhansen, 2 invisible),
147
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | I was at a swap meet and a older gentleman told me that I could replace my six bolt hub on the front of my 1939 Chevy JC 1/2 ton with a five stud hub from a Chevy car. He did not know what year of car would work. Is this true? If so what hub will work? I am replacing the rear end with a 51 Chevy car to get better highway gears and it has a five bolt pattern, I would like the bolt patterns to match. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't recall the exact years. Chevy cars were six lug for a long time. The five-lug hubs from when they switched, up through the '54 hubs should be the right ones.
Grab the front hubs off the '51 along with all the brake hardware including the backing plates.
On a '39 you'll probalby have to made some spacers to mount the backing plate in the right place.
I did this on a '41 1/2-ton about 35 years ago. You'd think I'd remember all the details... I remember something about using inner bearings from the truck and outer from the car, or maybe the other way around.
I'm sure someone else will jump in soon with more recent experience and better details.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Cars were 6 lug to '48, 5 lug started in '49 with the body change. Up to '54 sould be the same.
Bill Burmeister | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | When did cars switch to Bendix brakes? That would be the other issue if it was after 1948.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | I had a truck front axle here that had the 5 lug car setup fitted. I was told that it was from a 54 car, and that to fit the car hubs to the truck axle, you needed to use the car brake backplates and spacers as well as the car hubs and drums.
Stuart. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Whether or not you need the car backing plates and related parts depends on the year of the truck axle if I remember right. Some years you don't.
With something this old (1939) I'm sure you would need to swap them. When I did this with my '41 1/2-ton in the early 70's I did have to swap the backing plates and related parts.
I'd look for a '51 to '54 to get the Bendix brakes out of this swap too (thanks Bill).
