2 members (baldeagle, 78buckshot), 61 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#55112 01/17/2006 4:32 AM
Junior Member
Junior Member
I am doing this conversion on my '65 6 cylinder engine, :confused: what is a good donor truck for the power steering pump brackets?
#55113 01/17/2006 6:27 AM
For a 250?
Any Chevy truck, Camaro, Nova, full size Chevy car, Olds such as the Omega, Pontiac such as the Ventura or any GM car with a 250 with the same head you have and not the later integral head.
When you find one, check out the pulleys because they will probably be different than yours. The alternator bracket will be part of the pump bracket, so you have to see if it shares a belt and/or if its pulley is different than your alt pulley.
'67 GMC 3/4 292 4spd
#55114 01/17/2006 2:07 PM
Junior Member
Junior Member
I was told it was a 250, I am going to indentify it today ,Thanks for your reply.
#55115 01/18/2006 1:01 AM
Junior Member
Junior Member
Best I can tell is my motor is a 230, is it the same as a 250,as far as brackets go?
#55116 04/27/2006 5:16 AM
I'm doing the same coversion on my 69 C-10 Yes the brackets from any 250 GM without integral head will work. I'm having a little problem with fitting the brackets on my 292 Good luck!
