0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Can anyone help me in how to install the corner windows in a 1954 5 window. Does the rubber go in first and then the window or does the glass go in the rubber first and then installed.
Jon,
Do you have a 1954 Chevrolet Truck Shop Manual? It is a very handy item, if you plan on working-on and keeping the truck for a while.
The rear corner glass/windows installation is quite similar to procedure for the rear glass/window.
Note that the above link is to the 1954 Chevrolet Truck Shop Manual. This might save you having to buy a manual. Also, it has been nicely indexed with links to each sections menu. (thanks to Keith Hardy).
Tim
Jon I have a '52 5 window and went thru your grief. Link over to tech tips and read the article I wrote regarding the 5 window.
