8 members (Woodcmiami, Hotrod Lincoln, klhansen, DadsFirstPickup, Otto Skorzeny, MickeyP, Wayne67vert, 1 invisible),
50
Mod | | | Forums66 Topics128,043 Posts1,055,605 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | anybody have a pic. or Manuel showing how the top end gets its oil ?(56 235 chevy) I did not do the tear down and maybe missing parts. there is a oil tube from the rocker arm shaft to the head, a oil pass around the head bolt to a 1/8 pipe port but no access to that I thought it feed up the bolt from the block but with a bore scope that is a no go maybe a jumper line from a 1/8 threaded hole just above the lifters ? but then hows it get out from behind the cover ? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | The oil tube brings the oil from the head to the rockers. | | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | thanks 54tow I just found a tube in a box that goes from behind the rear lifter bore and feeds oil from the rear main to the 1/8 hole under the lifter/pushrod galley cover around the head bolt to the tube you mentioned THANKS | | |
