5 members (diseasel, Bill Hanlon, 59 fleet, Phak1, Wayne67vert), 109 guests, and 1 robot.
Topics128,035
Posts1,055,566
#550304 06/27/2009 5:54 PM
anybody have a pic. or Manuel showing how the top end gets its oil ?(56 235 chevy) I did not do the tear down and maybe missing parts. there is a oil tube from the rocker arm shaft to the head, a oil pass around the head bolt to a 1/8 pipe port but no access to that I thought it feed up the bolt from the block but with a bore scope that is a no go maybe a jumper line from a 1/8 threaded hole just above the lifters ? but then hows it get out from behind the cover ?
The oil tube brings the oil from the head to the rockers.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #550342 06/27/2009 8:53 PM
thanks 54tow I just found a tube in a box that goes from behind the rear lifter bore and feeds oil from the rear main to the 1/8 hole under the lifter/pushrod galley cover around the head bolt to the tube you mentioned THANKS
