| | | Forums66 Topics128,159 Posts1,057,027 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I want to replace my passenger side REAR axle because the bearing wore a groove into it. Can anyone tell me which years the axles would be the same as my 1955 1st series 1/2 ton Chevy Truck with the open drive shaft and the 10 bolt pumpkin? Thanks - Scott
55 1st Chev.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My master parts book lists #3832642 for RH on 51-59 ½-ton and 60-61 series 10. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Like Cletis said, starting in 51.... Your 1955 Axle Shaft is Here
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Cletis, Thanks for the help! Gotta get one of those books! -Scott
55 1st Chev.
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Oilrag, Thanks for the page. Prices look good too! -ha
-Scott
55 1st Chev.
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Well, I got out to the junk yard and removed the first axle. It looked perfect til my son noticed a small sratch in the surface of the axle where the bearing rides. We took out another and the pumpkin was full of water. We removed the axle and it was pitted and starting to wear where the roller bearings ride.
I found one at an on line junkyard and paid $100 delivered. Otherwise I was looking at 40 if I took it out or 60 if I had them do it. Shipping, if needed, was 20 or 25 more. I hope this is the source of my rumbling noise, but it sounded like it was up front, where I have already rebuilt the brakes and bearings.
FYI
55 1st Chev.
