0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
Newbie here, 54 chevy 3100 , bought in 94, torn down in 94, getting it put back together in 2009 (yeah I know I oughta write a book) Are tail lamps on when ever key in in the on position? new wiring harness installed and signal stat, will be putting new headlight switch in as well when shipped in.
Should mention this is a previous owner 12 volt conversion
welcome to the garage Cuzzie, there's lots here with projects running endless years ohwell
for your question - no, the tail lights are on only when you pull the light switch out one click, key on or off - brake lights work regardless of the key position too, must be some wire wrong causing one or the other to get power from the key, they should both get power from the light switch .... have a manual? wiring diagram in it should show the setup, and there's a techtip about the sig stat wiring that might help, problem could be there
Thanks Bill
will be checking it out after work tonight
cuz
Got it taken care of, wiring harness diagram and wiring harness were not completely in synch. Miss named the function of one of the wires whew!
