1 members (klhansen),
147
0
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 20 Apprentice | | Apprentice Joined: Jun 2009 Posts: 20 | Need general & electrical help with a 59 chevy apache...I want someone who knows their way around an old truck...any leads / references would be greatly appreciated.
Mike | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Apr 2007 Posts: 88 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 88 | My shop is in lady lake fl we are a outo cycle marine I serv. a few old bolts a have 3 now work on a few for cust. also have had 5 in the past 352-752-5267 Chris | | | | | Joined: Jun 2009 Posts: 20 Apprentice | | Apprentice Joined: Jun 2009 Posts: 20 | Thanks Chris - Lady Lake is a bit far, but i very much appreciate the response. If I cant find a trustworthy local, I'll give you a buzz. Thanks again sir. | | | | | Joined: Jun 2009 Posts: 20 Apprentice | | Apprentice Joined: Jun 2009 Posts: 20 | Big Chevy - I've got an original Rochester carb - I start the truck no problem, but after about 1 minute, gas starts spewing from the rear of the carb. I hate to admit it, but removing the carb is the extent of my carb knowledge - seems to me a rebuild is in order...Does that ring true to you? additionally, I've got some charging issues...go figure...thanks for asking - any input would be greatly appreciated - truth be told, I'm a novice...thanks again. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Mike There are a bunch of guys here that can answer that question. I'll bet you're able to tinker with that carb enough to fix it. This post has been on here a while and by now might not get any more hits. You might want to post the question on the Engine and Driveline forum.
~Jim
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | sounds like dirt or crud on your float causing it to overflow. do a search using "rochester" tons of info. | | |
