2 members (papas52, carbking), 69 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#548335 06/21/2009 1:17 AM
i have a 52 3800 pass door no matter what i do with the adj, i have a gap towards the bottomalmost a 1/2 in, it latches but way too much space at the bottom any suggestions thanks trying
Are you talking about the gap between the door and the rocker panel? This is quite common and I wouldn't speculate on the cause. To seal it just buy some thicker weather seal and glue it on in that area.
1951 1 Ton Completed
I think there was a thread once on bending the door using a 2x4.
Is it bent out away from the cab at the bottom or is it 1/2 inch too high?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
A gap? Where is the gap? Some pictures would be helpful.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
the gap is towards the bottom,at the rocker is the worst it gradual grows from the striker area down to the rocker, as if the door is not shut at the bottom, yes a pic would tell it all, maybe ican get sum 2day thanks all for your answers trying
trying:
My 52 panel has some rough fitting doors that I had gotten. After getting the doors to look good everywhere, except this one area, my body man actually ADDED a strip of metal to the edge of the door.... on one of the rear panel doors he actually ground off a bit to make it at least look "decent or acceptable".
These old trucks have been loaded, worked and twisted over the years and you just have to do what works.... oh, the body man cut the inside of one of my rear panel doors to get it to curve a little in at the bottom in order to fit the bottom contours of the body. Took out about a quarter inch, bent the door in and did his magic. Can't tell it now....
