| | | Forums66 Topics128,022 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | If I put the bolt spacer (blue) between the spindle and the backing plate, there is a gap. What would you do? http://img514.imageshack.us/img514/516/gapq.jpg
'59 Apache '67 Mustang
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ApachePride, are you reassembling after a teardown/cleaning/painting, or are you assembling some parts new to the truck? Your backing plates must be mounted perpendicular to your spindle, they must not be twisted, they must be well supported, and tight, your life and the lives of those around you on the road depend on their proper installation, hope that helps. | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | I am reassembling only the old parts. That is why I am so amazed. That means that I have to trim the bush / bolt spacer?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ApachePride, If you are only reassemling your old parts, and there was no problem before, then things should fall back into place. Have you counted up all your hardware to make sure you have two sets of everything. You definately should not have to modify anything! Hope that helps. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Looks like it's supposed to have a GAP. | | |
