| | | Forums66 Topics128,030 Posts1,055,421 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54830 01/12/2006 12:39 AM | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Trying to rebuild the column shifter on a 1955 2nd series. I bought a rebuild kit but I'm not sure of the spring placement. Does the spring sit in the buttons? I'm really lost on this one. The old shifter didn't have the spring. Any information will be helpful. Bob | | |
#54831 01/12/2006 7:10 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Bob,
You are correct. The buttons fit on the end of the spring. That is what keeps the buttons in the holes of the shifter arm.
When I rebuilt mine the spring was broken.
Best of luck.
Dennis -there is nothing stronger than the heart of a volunteer-
#54833 01/13/2006 10:53 PM | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Thanks, I'm not sure what that spring does yet. There's also a collar that holds the buttons | | |
#54834 01/13/2006 11:26 PM | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | Here's another pic, Bob [img] http://www.laroke.com/larryk4674/2000/bb092300at.jpg[/img] Bigger Picture Still assuming that your 55 2nd series is similar to my 55 1st series, I believe the "wishbone" shaped spring is to keep pressure on the backside of the pivot buttons as stated by Dennis above. That little sheetmetal collar fits inside the machined pivot saddle and restrains the spring from pushing the buttons too far out. When you reinstall the shift lever, the buttons depress slightly against the spring until the lever housing is down to its installed position, shown below [img] http://www.laroke.com/larryk4674/2001/bb032501at.jpg[/img] Bigger Picture Then the spring pops the buttons back out (and holds them) so that the shift lever can pivot off of them. | | |
#54835 01/14/2006 12:08 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes Larry - your pics are identical to the TF series shifters, even the knob!
Bill | | |
#54836 01/14/2006 3:47 PM | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | Glad to have that confirmed. Thanx Bill. | | |
