| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 5 New Guy | | New Guy Joined: Jan 2007 Posts: 5 | Been reading posts on here for a while now, I think this might be my first post.
I have a 58 Apache Fleetside, the bed is at a hotrod shop here locally, getting the 5 star treatment, since I can't mess up a fleetside bed and think a replacement will be available.
So I'm leaving the cab to me. I have both cab corners, both steps/rockers, the passenger side floor/toeboard to start. It needs door bottoms, and a few small patches here and there.
Right now I have cut out the passenger cab corner, the passenger step, and I'm staring at the passneger floorboard. My worry is the door frame springing as soon as I cut the floor. I want to brace it before cutting, my real question is can I weld in the cab corner and step, then move onto the floor?
I feel sorry for people that don't drink, because when they wake up in the morning, that is the best they'll feel all day. -Frank Sinatra
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | definitely finish the steps before the floor, one piece at a time not everything at once - if the cab is off the frame when you cut the floor, tack weld some braces in the door openings first
Bill | | | | | Joined: Jan 2007 Posts: 5 New Guy | | New Guy Joined: Jan 2007 Posts: 5 | Well, I finished the cab corner. The welds look good, no worries with warping, I think I'd really have to torch it to warp it. Problem is, I measured 14 times, and the 14th time I convinced myself to trim off too much material. So I went back with strips behind the gap to help close it up. Pretty good actually all things considered. Unfortunately the cab corner isn't straight when looking at the vertical line between the cab/bed front. I'm a little worried now with my ability to make good cuts with a cutoff wheel. Do you guys think a pair of sheet metal sheers is an option? My Dad thinks it will deform the metal too much.
