7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | In the kingpin kits there is a lock pin that has an incline and threads. It holds the kingpin in place. I need just the lock pin. I have tried LMC & Jim Carter but they will only allow me to order the entire kit. NAPA can't get it either. Is there another company out there that I should check with or should I have a machinist attempt to build new ones
1952 3600 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I think I still have the old pins out of my 38 but I don't know if they'll fit your 52. Do you know the dimensions of the lock pin?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Try an ad in the swap meet for a used one. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Try clasic I beleive they sell them .
Pete | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You may find that another set of lock pins won't fit. There is nothing about the design that would require the machining on the flat of the kingpin to be the same between different manufacturers. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Pete, there are about a dozen vendors that use classic in their names, which specific one were you refering to?? DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | www.classicparts.com has the parts look where they sell the king pin sets. part # 74-091 9.95 each Pete
| | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | www.classicparts.com has the parts look where they sell the king pin sets. part # 74-091 9.95 each Pete 74-091 is the pin used for the rear springs, I didn't believe they were the same size. I don't have the parts in front of though so I am not certain. | | |
