4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#546979 06/15/2009 10:50 PM
In the kingpin kits there is a lock pin that has an incline and threads. It holds the kingpin in place. I need just the lock pin. I have tried LMC & Jim Carter but they will only allow me to order the entire kit. NAPA can't get it either. Is there another company out there that I should check with or should I have a machinist attempt to build new ones
1952 3600
cshamel #546996 06/16/2009 12:07 AM
Ex Hall Monitor
Ex Hall Monitor
I think I still have the old pins out of my 38 but I don't know if they'll fit your 52. Do you know the dimensions of the lock pin?
Tiny #547015 06/16/2009 1:23 AM
Try an ad in the swap meet for a used one.
Cletis #547025 06/16/2009 2:13 AM
Try clasic I beleive they sell them .
Pete
Pete52 #547127 06/16/2009 11:39 AM
You may find that another set of lock pins won't fit. There is nothing about the design that would require the machining on the flat of the kingpin to be the same between different manufacturers.
1951 1 Ton Completed
Pete52 #547128 06/16/2009 11:40 AM
Hey Pete, there are about a dozen vendors that use classic in their names, which specific one were you refering to??
DG
Denny G
Sandwich, IL
www.classicparts.com has the parts look where they sell the king pin sets.
part # 74-091
9.95 each
Pete
Pete52 #547925 06/19/2009 2:33 AM
part # 74-091
9.95 each
Pete
74-091 is the pin used for the rear springs, I didn't believe they were the same size. I don't have the parts in front of though so I am not certain.
