| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | I got 0 results back when i searched muriatic or hydrochloric acid.
I used to clean pools and can tell you there were some awfully clean bare metal spots in the bed of my truck from the muriatic acid drips. The price difference makes this acid tempting compared to phosphoric. Body shops seem to use only phosphoric. Anybody know why? Are there any problems in using this to etch and/or clean metal before painting?
Dave
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Phosphoric acid is much safer to work with. I use muriatic acid to clean/etch old gas tanks. I wouldn't use it to prep metal for body work or paint. It's far too reactive to be safe.
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Muriatic acid is reported to cause hydrogen embrittlement in steel. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | Phosphoric acid converts the iron oxide (rust)to iron phosphate. The iron phosphate inhibits the formation of new rust. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | neilroy nailed it.  | | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | As stated in The Standerd Guide to Automotive Restoration by Matt Joseph an old but very helpfull book, the use of muriatic acid has "slipped into disuse and properly so. This is a lost art and should remain so." I use phos only when I must and try not to. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks for the input, men. After further reading, online, HCL does well to remove the rust but can also be harsh on iron itself (and removing iron from the steal alloy would definitely cause embrittlement). The reaction produces a liquid solution (no protective layer as with iron phosphate). And it is dangerous to use (but what isn't...). So it looks like everyone is right on this one. I'll probably still try it, though Thanks, again.
Dave
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I purchase Phosphoric acid at Home Depot. It is in the paint section as a metal prep. Lowes does not carry the same product in my area. It is 13 or 14 dollars a gallon. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks, Lonnie. I bought some and I'll try it too. It looks like it's only 50% acid. Will paint/body shops have 100%?
Dave
