| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | took My 216 out of My 52-3100 in dec. and than a guy gave Me a 235 so My brother in law and I removed the 235 off the frame somehow the two carbs got into the box of parts for the 216 now I am cleaning all the stuff for the 216 to start the rebuild and I got two carbs they look the same so does anyone know which is which? Thanks, Pete | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The 235 carb is slightly larger at the base and won't fit the 216 manifold. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks I will give it shot tomorrow , Pete | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 216 Rochester 'B' hole centerline is 2 11/16" and the 235 is 2 15/16" Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks , got the right carb for the 216 and all is well , also finished the other cab corner today so sheetmetal on cab is DONE just gotto install seat belt brackets { got to so I can take Grandkids with Me}.
Pete | | |
