2 members (2-Ton, 1 invisible), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#54312 01/02/2006 6:25 PM
I took my steering box from my 61 and took it all a part to see how worn out it was. Other than the old nasty grease, it looks good. Some new seals and grease and it will be good as new. What should I use for grease? I was thinking of wheel bearing grease, but that seems to heavy. I also thought of the grease used in CV joints but not sure I can just get the grease. Any other ideas on what to use?
#54313 01/02/2006 6:57 PM
I use moly grease w/ a bit of moly-slip gear additive to make sure it coats everything - a past thread on it - and another
