3 members (baldeagle, 2-Ton, Stovebolt48), 81 guests, and 4 robots.
Topics128,014
Posts1,055,332
Members48,419
#541012 05/26/2009 4:05 PM
Should any parts inside the engine compartment be painted with special paint because of the heat?? Does this also include the inside fender wells?
nothing except the block and manifold ["engine enamel"], if anything else under there gets that hot you better bail out wink the inner fenders and such are normally just a standard satin/semi-gloss black
So things like the thermostat housing and fan blade are also just regular paint?
the fan yes, the housing would have been painted already on the engine
