9 members (rfs56trk, 78buckshot, 2-Ton, Gdads51, Wheelie, Deegs53, Peggy M, Gray_Ghost, 1 invisible),
149
Mod | | | Forums66 Topics128,078 Posts1,056,024 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53880 12/23/2005 4:29 AM | Joined: Mar 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 70 | I have a line on a truck, the owner wants a pair of 1 ton rear brake drums, have seen several in the area and am wondering what years are the same and if all one tons have the same drums ie single or dual rear wheels | | |
#53881 12/23/2005 9:04 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I know that the rear ends on 1 tons was more or less the same from like 48-73 - or at least they used the same seals and brake shoes 14x2.
I myself am trying to find a set of rear brake drums. Kind of rare. (That is good ones) | | |
#53882 12/27/2005 2:38 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think that you will find that the gear assembly could be interchanged between 48 and 72. The other features of the rearends did not stay the same. In 52 or 53 they switched the brakes away from the Huck brakes and I believe the drums changed too.
Finding good used drums is pretty difficult, isn't it? | | |
