| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Gentlemen the next 292 project is being conceived in thought. The new engine should have 50-75 more HP than the current. Anyways I want to know what type piston rings to buy for longevity. I only know of moly and standard cast. Is there anything else reasonable worth considering for a street engine?
-ftyler | | | | | | Anonymous Unregistered | | Anonymous Unregistered | FT - go with gapless rings from - a set for a 292 is about $125. That is what my motor will be running . . . once I get this head figured out. :rolleyes: | | |
#5371 03/17/2004 12:28 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Yeah ,gapless rings can reduce compression leakdown to less than 2%. But not all engine builders are thrilled with gapless rings.Some say outside of special racing needs ,they aren't necessary, they have problems in some applications and they are quite expensive.But I have no experience with them so........ I also hear that Deves rings are very good,made of steel rather than cast iron or cast coated with moly or chrome. It's no secret that hi output Japanese engines maintain excellent cylinder sealing for 200K miles and beyond, what rings do they use? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I bought gapless for three reasons . . .
1.) a 292 bored 0.040 over with Ross racing pistons (compression rings are 1/16 - oil rings are 3/16) make choices pretty narrow.
2.) after talking to the guys at Ross and Speed-o-motive, they were both complimentary on the gapless ring for better compression and cleaner oil due to less blow by.
3.) The money is spent . . . the engine is going back together with a few modifications - I don't want to switch rings now!
I'll let you know how they work out once it is all buttoned up and running in the burb. . . which still may be a while :rolleyes: | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Tony you're absolutely right about Japanese engines. My low-output (200 HP peak) 3.2L v6 Acura has 225,000+ miles and runs cleaner than my new 292. By far. I run this engine daily at 3,000 rpms and the exhaust is as clean as when I bought the car 8 years ago with 48k/miles.
I thought they used moly rings. If those rings you and Ken mention are really that good then I'll bite the bullet and get a set.
Thanks guys! -ftyler | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Stay away from total seal moly rings in a street engine. Several engine builders have told me that TS moly rings show excessive oil consumption and cylinder wear on street engines. My new 235 has total seals, and it burns oil. When I pinpoint the problem I'll post back.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Newer technology like gapless rings will always have those who say it's nothing, But Ken will know for sure,the best way to find out, just do it. | | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | I have always had good results with Hastings ring sets in my Chevy and Harley engines. Moly top, cast second, three piece oil, with final hone finish 320 sc grit @ 60 degrees crosshatch. They usually seat in under 100 miles and if the engine isn't run hot they will last till the rods start knocking.
Rust is my favorite color
| | | | | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | "It's no secret that hi output Japanese engines maintain excellent cylinder sealing for 200K miles and beyond, what rings do they use?"
Toyota OE rings are cast and they last forever. I'm at an independent now and we use Hastings with good success.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Gentlemen the next 292 project is being conceived in thought. Go Brother Go! Build ya a screamin hot V-8 eatin' monster, and then post the exact specs and procedures for everything here in the forum so I can copy you as soon as I finish my continuing education! (No money while working 2 days a week and going to school, but a man's gotta do what a man's gotta do)  Bob  | | |
