1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I have a 58gmc 270zenith carburetor.set the timing by the flywheel mark.Rotor pointed at #1 wire.points were open.carb set at 1turn needle valve,2.5 turns on main screw.After warmed up;took it around the block,no problem.Went to store(5min trip)took 35mins.Overheated,stalled 3 times&barely was able to get it back home.WHAT"S going on ?Guess Ill replace the thermostat(Which I did4months back).Why would it seem to do okay at idle but then no power?Couldnt give any gas whatso ever. Danny | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Check the timing with a timing light, or by ear if that works for you. One symptom of overly advanced timing is overheating, not sure that is any or all of your problem, but it is worth looking at.
Also, the number of turns for the carb adjustments are only starting points, you need to tune by ear and trial and error from there.
Grigg | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | dtwbcs,
I would do a compression check on it after it's real warm. Some overheating could be associated with timing but yours almost sounds like a blown head gasket.
A functioning radiator should have the capacity to cool it down even after getting hot, could yours be plugged or dirty.
When a engine get real hot, all kinds of things start to happen. Marginal ignitions fall apart, fuel systems start to boil and act strange and things just get weird. If you are using coolant, this could support a blown head gasket or cracked head theory.
Stuart | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Set the timing manually yesterday.Had it idling fairly smooth.How would you check a clogged radiator?send it to the shop?If it has a blown gasket,would the oil look milky?will the engine actup only after warmedup?I noticed the idle seemed to have dropped.was "popping"out the exhaust pipe while driving down the road.How can I prevent the distributor from"walking"after I set the timing? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Did you drill a hole in the thermostat to let air escape when you filled it with coolant? | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | First thought I had was air in the cooling system, but after you said "popping" out the exhaust I would lean more towards timing or valves. Did you do a compression test? Could be a burned or bent valve?
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | how old is the radiator ? could it be cloged or have poor airflow ? i had that happen to me once. if it idles fine and only heats up when the engine is loaded that may be the cause. if you can look inside the radiator via the filler cap check to see if the flues you can see are clogged. if thats the case have it rodded out or replace it.
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Consider inspecting the manifold hotbox. If it is burnt thru , there will be issues similar to what you describe. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I took the thermostat out&buttened it back up.reset timing using a light.was looking inside of the radiator for water circulation.-noticed tiny bubbles about half the size of a BB every so often.idled the truck for a while before backing into garage. Danny | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Put a new thermostat in&It seems to be doing fine.Guessing the thermostat was stuck-closed
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
