| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 60 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 60 | I cant get it to start driving me insane! I have good spark and I'm getting fuel. Checked base timing I think it's good but all I can get is a backfire out the carb am I 180 out of time help! | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Sounds like it. Turn the engine over to where the the timing marks line up and pull the distr cap and see if your one #1.
Is this a fresh rebuild? did you replace the plug wires? Adjust the valves?
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Pull the valve cover and watch the valves move as you roll the engine over clockwise from the front. Get the #6 exhaust valve closing and the intake opening. This is known as "overlap", indicating that the #6 piston is at the top of the exhaust stroke. Now, look at the distributor rotor, and it should be pointing to the #1 cylinder plug wire. If not, rewire the distributor using the cap tower the rotor is pointing to as #1. The firing order, going clockwise, is 1-5-3-6-2-4. Button everything up and fire it up! Jerry
