0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#535472 05/07/2009 1:41 AM
I've got a rolling axle assembly - it is "supposed" to be off of a '67 or '68 - but you never know.
I had one numbers book in my hands, but could not find a match for the digits I found.
On the forward facing was:
CFO (CFD?)
90
3977323
I popped it open, and on the ring gear is:
3977334 10 41 376
Teeth count is 41 and 10 if I didn't go crosseyed.
Of course, the big question is, will this fit in my pumpkin? The rear end cover on my '56 looks much bigger than this rolling axle. The swap is likely above my abilities, but I guess first I need to know if the swap is physically possible.
I've got a buddy who suggests that it would be easier to swap the whole rolling axle assembly (which he's done before) than the pumpkin innards (which he's never done). Have not done any measurements yet, though.
Thanks for the help, guys.
1956 Chevy 3600 Dually
3B Offline
Hy cfesting, my newest parts book goes up to 73, and that number is not listed there, so it must be a newer number than 73, the last 3 digits you found [376] could be a date code for march of 76, hope that helps.
3B #535712 05/07/2009 8:14 PM
Thanks for the info, 3B. That helped get me on the right track. It was also quite a surprise, and a testament to the "you really don't know who replaced what with what" on trucks that have been around for a while.
Using this info (and the interwebs) I believe this is a 14 bolt GM - possibly a a Full Floater with a 10.5 Ring Gear - and from 1976. If anyone can verify this, or add any other geeky info, that would be great. It is a dually, by the way.
And, I also assume that this means no swapping of the innards. Bummer.
Thanks, all!
