| | | Forums66 Topics128,157 Posts1,056,877 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53473 12/14/2005 5:33 AM | | Anonymous Unregistered | | Anonymous Unregistered | It seems that one of the ram horn exhaust manifolds I pulled off the wall to use has two of the three stud holes slightly wallowed out enough to prevent the new studs from securly threading into the exit flange. Other than buying a replacement manifold or welding the studs into place, yuck, what other methods of repairing these two holes do I have available? These are cast iron manifolds with the rear swept exits. | | |
#53474 12/14/2005 6:52 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | You could try helicoils. I have used them in heads so they can get hot. An older trick is to cram foil in there and then the threads will catch on the foil and go. You could also get some metric studs that are slightly larger and use them after re-tapping. I have done that as well. JB Weld might work - people have used it on blocks. One other option is to change to a regular bolt - pass it through and then put a nut on the end of it. I have done that as well. | | |
#53475 12/14/2005 2:13 PM | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | You might try getting some studs that are bigger on th short thread end tap to the next size the have the original stud size still where thy go thru your xhaust pipe flange....Ronnie | | |
#53476 12/15/2005 1:34 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Houston 54, I repair these holes by brazing around the outer circumference of the hole then drill and retap. | | |
#53477 12/15/2005 4:30 AM | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | JB weld will not work on high heat, it just melts away.
Super250six | | |
#53478 12/15/2005 5:36 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | If the hole isn't washed out too big a helicoil will give a permanent and virtually invisible repair. For example if the stud is 3/8" fine thread the drill size would be 25/64" or .390" If the hole is larger than the drill size another method should be used. Here's a tap drill chart for helicoils. http://www.carbidedepot.com/formulas-tap-helicoil.htm Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#53479 12/16/2005 1:44 AM | Joined: Apr 2005 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 42 | I'd say the helicoil is your best bet. Helicoil is a brand name so you can find the same product sometimes under the name "recoil" & save a few bucks. | | |
#53480 12/16/2005 5:09 AM | | Anonymous Unregistered | | Anonymous Unregistered | Half of the problem has been solved as I drilled and tapped one hole for 7/16-14 thread and got a replacement stud from a local muffler shop. The other hole is going to be more of a problem. | | |
