1 members (1 invisible),
56
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | I know this topic has been touched upon in the archives, but I have no spark to my plugs. Is there a step by step method I can use to find what's wrong (coil, distributor...). I have battery to starter and battery to positive coil. Should it be starter to coil? Do I need to ground coil. Could coil be bad? It's a rebuilt engine so everything is new. Please help!!!
1946 2 Ton Flatbed
| | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | I have a weak spark at the end of the coil wire that feeds into the distributor cap, but nothing from distributor to plugs. This is a fresh rebuild, so I only have wires running from the battery to the starter and the side of the starter to the coil. Should I run anymore wire? Should I ground the battery in a particular location? Could I have a bad coil? Any advice would be greatly appreciated.
1946 2 Ton Flatbed
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i always check and clean the points first if i have no spark, or i did until i put an hei in my 46 now i always have spark. philip | | |
