| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | Please help identify the following. L53S013443-Door Plate 0I94604F56V--Engine near distributor 3836848 GM12--Other side of engine I have included photos of the numbers. THanks http://s732.photobucket.com/albums/ww324/huthip/idnumbers/
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The door plate indicates a '53 1-ton, 3800 series. The engine has been updated with a '56 235 full-pressure truck engine. It also has the desirable "848" head on it. Got any pics of the truck? | | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | Yes, under Big Bolts "Got permission to buy first stovebolt" I have link to the photos of the truck.
Just curious, why is the "848" head desirable? I don't know much about this stuff so I am trying to learn.
THanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It seems that the "848" head was used on all 235s from 1956 and onwards. After 1956, it was also the replacement head for any 235 for any 1954 and later 235.
The "848" head's design results in higher compression (and thus, higher horsepower) when used on an engine that did not come with a 848 head.
The head could also be adapted to work on any 261 engine (which was available from 1954-1963). The 261 was always lower compression than the same year 235.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | what tc said and also the "848" supposedly flows better than previous designs. It first showed up on the famous 6-cyl Blue Flame engine of the '53 Corvette. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | waldo53, All I know about 1953-55 235 heads is from the 1929-1954 Master Parts Catalog. It does not show an 848 head as being available in 1954. However, the 848 head was available as the replacement head for all high-pressure 235s by 1957.The 1953-55 Corvette's 235 head casting codes, supposedly, were: 1953: 3836066 (150 hp) 1954: 3836241 (150/155 hp) 1955: 3836241 (155 hp) All three of these heads had a smaller diameter hole for the older temperature sensor. Tim | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | tc; Maybe I'm not reading this right but look at the Corvette 235 casting number here. Isn't this saying the "848" casting number started in '53? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That could be read that way. But it could also be read that it is used as a service part for 235 full pressure back to '53 as well.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | waldo,
You are reading it right. The Master Parts Catalog, as Bill posted, shows replacement part numbers (that's why I showed both the 54 and the 57 Catalogs' entries). The 848 head was not shown in 54 but it shows up in 57 - the 848 head first became available in 1956 and was the standard replacement head until the end of its run).
I'd be willing to bet that a Corvette-purists' discussion board would quickly (and probably rudely) state that an 848 head was not an original (year-matching) part.
Finally, other indirect evidence that an 848 head was not used on any 53-55 Corvette 235, would be the size of the hole for the temperature sender. An adapter is needed in order to use a 55 or earlier temperature sender in an 848 head.
Tim
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | O.K., my bad for stating it came on the '53 Corvette. Could we safely assume though that the flow and compression characteristics of the "848" were at least on par with the original Corvette heads since as a replacement part I would think the HP ratings of the Corvette engines would still be the same, or very close to the same, with the "848". What think ye?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The increased hp in 1953-1955 Corvettes was probably due to the dual exhausts and the three one-barrel side-draft carbs.
In mid 1954, the 235 Corvette's hp increased from 150 to 155, due to the use of a higher-lift 261 cam.
I'd bet the hp in any of the 235 Corvette engines would increase somewhat if an 848 head was put on one. People who put the higher-compression 848 head on a 261 report an increase in hp.
