| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi All. I bought a power brake set up that included the master cyliner and the booster. The master cylinder has four outlets, two on each side. I only need two of the four outlets, one for front disc brakes and one for drum rear brakes. Can I plug the two outlets on the side toward the frame and use the two that are exposed? What do you think? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rick in VA, it sounds like you have a universal type master cylinder, probably purchased from an aftermarket supplier. The instructions that came with it should confirm, but I think you should be able to use whichever ports are the most convenient, and plug the unused ones, hope that helps | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | There are ports on each side of the MC so you can choose. Just make sure you use a front and rear port and not both fronts or both rears. I know that may sound dumb, but dumber things have happened before. | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi Lonnie, I knew better but it never hurts to say! Thanks! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, I am looking for a company I can buy a stock master cylinder for my 1957 Chevy 3100 1/2ton truck. Is it still possible to buy one made in the USA? I see prices from $70 on up to almost $200. Thank you! Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
