| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 47 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 47 | I was wondering if there is a gasket between the oil pump and the rear main cap? Also is there a gasket between the oil filter mount assembly and the block casting where it mounts?
There was gaskets between them during tear down but no one shows them. Any help would be greatly appreciated. The block is about a 1980 according to casting numbers if it makes a difference.
Old Chevy | | | | | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | No need for a gasket between the pump and the main cap. I seem to remember a gasket under the filter adapter, but not all gasket kits have them. Shouldn't make a difference, as long as it's bolted on tight. Jerry
| | | | | Joined: Jan 2009 Posts: 47 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 47 | Thanks for the help.
Old Chevy | | |
