4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
bought a 1948 COE with 50K original miles.looking for ideas to make it driver friendly
What does driver friendly mean? How will you be using it?
Get in it and drive...
With a smile on your face!
•1952 Chevrolet 3800 pickup
---All pictures---
i would like to make it a daily driver, and keep it as stock as i can.
Love to see pictures! thumbs_up
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
Big Bolt Forum Co-moderator
Grigg, I love that.
1948 Chevy 2-Ton
Did you just answer your own question?
I still say "get in it and drive", with a smile of course.
What are you concerned about?
Grigg
---All pictures---
Keeping it stock as possible both limits things and suggests some likely approaches.
Make sure the brakes including the hydravac are all in tip top shape.
Adjust the clutch and replace if necessary.
Make sure whatever wheels you are running have the right offset to minimize steering effort, and make sure all the bushings, king pins, tie rods, drag link etc., are all properly lubed, and replaced if worn.
In short, I'm suggesting a stock truck is going to be most driver friendly if everything is in good shape and well maintained.
You say you want it to be a daily driver. Do you mean a daily working truck or are you saying you're going to use a 60 year old 2-ton truck like a car?
