| | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53099 12/01/2005 4:01 PM | Joined: May 2005 Posts: 25 New Guy | | New Guy Joined: May 2005 Posts: 25 | Will a steering wheel from a 47 Chev fit a 41?
My 41 wheel is ragged and the newer one is available. | | |
#53100 12/01/2005 5:17 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'm not sure the 47 wheel will fit on your column. The 47 wheel has a different shape than the 41 and I'm not sure it would fit on the steering shaft. Is your original too far gone to repair? It isn't that hard to fix up your old steering wheel. I would try to salvage what you have. George | | |
#53101 12/01/2005 6:16 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It should be no problem. 1940-48 pass use the same steering box.
If it's a truck the splines will be the same. If you mean 1947 second design it had a larger column so the horn contacts will not line up.
See the USA in your vintage Chevrolet! My Blog | | |
#53102 12/01/2005 6:18 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | my .02 i think in 48 they changed to the multiple splined shaft but prior to 48 was a keyway good luck ... it can't be that difficult a job to try.
let us know the out come.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
