8 members (kurbside bolter, tclederman, FAST55, Hotrod Lincoln, KEVINSKI, 1955 1 Series, Charles in CA, Otto Skorzeny),
157
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 67 | I am putting a 1959 235 out of a car in a 52 AD truck and I know that the long shaft 59 water pump won't clear the radiator. I have seen in Patrick's catalog they have a short shaft water pump that is made to fit the 55-62 235s but that thing is $139.95 and times are tight right now !! and if it wears out I can't go to the local parts house and get another one . I have also seen a adapter plate on Ebay for $40.00. My queston is has anybody ever tryed to made one of these adapters? If so could you give me some advice on how to make one. I know I am a cheep scape but like I said money is tight right now!! THANKS SlickT
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | If you do a search you will find someone who made one. | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | the adaptor plate picks the water pump up into the position it would have been in an earlier truck w/ a 216 motor. i am using one on a 261 build that i am putting in a 46 1/2 ton. i believe the pump you are looking for is a 53-54 w/a 3/8 pulley #3836084. this pump is available in a modern build through napa and rock auto. double check the pump # as i dont have my books w/ me right now.
making a short shaft pump requires pushing the shaft throught he pump body and grinding off the hardened shaft to the correct length. try searching using the pump # abaove or w/ key words such as shortened pump or water pump clearance, short shaft water pump.
big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I have the short shaft water pump on my '48 Chevy truck (1960 -235 engine). I bought it from Patricks - It's been on the truck for 10 yrs, and 39,000 miles with no problems. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | The adapter plate wouldn"t be that hard to make if you could find the right thickness metal. You could transfer all of the hole location by useing gaskets and the old 216 water pump. A plasma cutter would be nice to make all of the outside cuts and the two holes for the water flow. If you decide touse the old 216 pump you will need the balancer as well so the fan and pump won't turn to fast. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The adapter plate wouldn"t be that hard to make if you could find the right thickness metal. That would be 1/8" which is the same as the plate that is removed from the back of the 216 pump and replaced by the adapter plate.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i made mine. the back plate off of the old water pump can be used as a template then a water pump gasket for the new engine will make the bottom template. you will have to drill and tap 2 holes in the block. its simple just make sure to seal it up good. | | | | | Joined: Apr 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 67 | | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | Patricks sells the plate and it si not expensive. My understanding is the long shaft radiator is there for a reason and over heating can occue when water pumps w/ short and long shaft are swapped out. this will also affect what fan blade you can use as the center hole changes diameter for which pump you use
56 stepside 3/4 ton longbed
| | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | relocation plate is also available on ebay from pre68dave,i bought one and it is a very nice piece. and he is a bolt member
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you buy the plate, be sure to ask for installation instructions to be sent with the plate. If they do not have installation instructions, buy the plate from Jim Carter (and ask for the instructions).
| | | | | Joined: Apr 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 67 | Thanks for all the advice !!!! I really appreciate it!! THANKS SlickT | | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | I did this years ago with a 59235 into a 51 chevy pu/ I as I recall, the trick was to remove the fan support which is pressed onto the pump shaft. Then the shaft had to be cut a hack saw would not touch the diecast metal so I had to use a grinder to perforate the diecast surface, then hacksaw did the trick. I dressed the end with a file pressed the fan support back on to the shortened shaft and put it together, the dimension for the support was determined by the flat plane of the fanbelt with the generator and the crankpulley | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have done them the way pgosset explains however, the earlier pulley is too small for that pump. It will turn too fast. Find a pulley near the diameter of the later pulley. One from a 292 Ford works if you can find it.
By the way, a cut-off wheel in a die grinder makes short work of cutting the shaft. | | |
