0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I have a '58 235 engine (6 cylinder) in my '49 3100. My '58 Shop Manual shows separate diagrams for a 6-cylinder fuel pump and an 8-cylinder fuel pump. The fuel pump installed on my 6-cylinder engine is clearly the 8-cylinder model.
At the time I purchased the truck, the engine was not running, but the fuel pump was working. I know this because I watched it pump fuel into the glass filter and carburetor. This leaves me with several questions. Is this the original pump for this engine or did somebody replace it? In other words, did Chevrolet start using the 8-cylinder pumps on 6-cylinder engines or did the previous owner install the wrong pump? Are these pumps supposed to be interchangeable? The shop manual says the 8-cylinder pump is a higher capacity pump (which I would expect for a larger engine). Can I use the 8-cylinder pump on my 235, or will it swamp the carburetor and engine with too much fuel? Final question is how do I get this dang pump apart. The shop manual says to compress the main spring slightly and unhook the diaphragm from the rocker shaft. No luck for me. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Norcal49er,
I can't offer anything but a WOW, I had no idea both pumps were so close in design. I looked in the old online shop manuals and other than the actuation arm, they look similar.
I wonder if they are interchangeable without detrimental effects. I'm assuming you are trying to dissemble it to rebuild it. Isn't there a new pump available for your engine at the corner auto parts store.
Stuart | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | NAPA Fuel Pump (OE Mechanical Type) w/ Electric Wipers BSH N68553 $25.99 (new)
About 1/4th the cost of the 8-cylinder mechanical fuel pump (sell your used one on eBay).
A 1954/55 fuel pump will work on that engine and the orientation of the fuel lines would be the same as the original (the 1957 and later 235/261 fuel-pump's fuel lines are in a different orientation). This might not make a difference to you, if your existing fuel lines are already matched up to a 1958 fuel pump.
| | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Thanks. I cleaned and inspected the old one and stuck it back on. If it doesn't work, it's nice to know there's an inexpensive replacement available. Not much to them, though, so I wouldn't be surprised if this one lasts another 60 years. | | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | ... I wouldn't be surprised if this one lasts another 60 years. Norcal -- That's what I thought, too. My '65 GMC still was running the original fuel pump last year when I was in the middle of a 300-mile round trip to a show (in convoy with several other trucks). I thought what the heck, the truck only had (at the time) 8,000 miles on it. Well, after 40-plus years of mostly sitting, the diaphram wasn't able to withstand modern gas and disintegrated causing a series of issues not the least of which was an engine compartment fire. Nothing like seeing a burning fire truck ... Not trying to scare you. But 25 bucks? Give yourself some cheap insurance and just go ahead and replace it.  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | John is right. This new fuel we get with ethanol & who knows what else in it can eat up an old pump & hoses. Even stalled out a mile from home can be traumatic. I can't imagine a V-8 pump fitting on a 6. Maybe it just looks like it. They have changed the design several times during the years. The replacement doesn't always look like the original. Some had a glass bowl strainer under them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Yikes! I think I'll buy a new pump. Like Wrenchbender, I got to thinking maybe this IS a new pump and it only looks like the original. My pump has a metal tag on it that is stamped... AC E6 531. Does this mean anything to anybody? | | |
