1 members (Ponchogl), 163 guests, and 3 robots.
Topics128,101
Posts1,056,182
Members48,436
#528783 04/15/2009 8:51 PM
i have a 1948 1.5 ton 4400 series i cannot find any rear axle seals for this truck ant suggestions
remember rust is our friend
3B Offline
Hy 57chevydelivery, are you looking for hub/wheel seals, pinion seal, or axle seals?
axle seals
3B Offline
Hy 57chevydelivery, I could only find listings for a wheel/hub seal and a pinion seal for that axle. I will give you the wheel/hub seal numbers and dimensions, in case that's what you want. Wheel/hub seal dimensions 3.188"X4.625"X.5625", Napa p/n NOS31870 $29.99, Rock Auto [National] 6358 $21.79. If you are looking for the outer wheelbearing locknut with the rubber seal built in, those were a GM part and are no longer available, as far as I know. They were for grease packed rear wheel bearings, if you clean the grease out and omit the rubber seal at the wheelbearing nut, your bearings will become the oil lubricated type. Hope that helps.
