7 members (klhansen, 87GN, tclederman, Stovebolt48, Peggy M, baldeagle, 1 invisible), 117 guests, and 1 robot.
Topics128,048
Posts1,055,666
#528696 04/15/2009 3:10 PM
I have a 2nd series '55 and every time I remove the gas cap it makes a sound like I'm relieving a vacuum. I always thought it was normal, but now it keeps stalling and will only idle. The fuel filter is clean. It will idle perfect, but as soon as I hit the gas it stumbles. If I shut it off for a minute or two it's ok for a little while. Should it actually have a vented gas cap on it? It has always made that noise and I have driven it 2 hours at a crack with no troubles so I don't know why all of a sudden I'm having trouble.
Help please!
yes the cap should be a vented one.As the fuel pump removes fuel from the tank, an equal amount of air must replace it,or a vacuum is created.I think the amount of fuel in the tank would affect the drivability.The fuller the tank,the sooner a vacuum is created
Ex Hall Monitor
Ex Hall Monitor
An addendum to BC52's post. One possible reason you are now having difficulty where you didn't in the past could be that you had a strong enough fuel pump to pull enough air into the tank past the unvented cap to allow the engine to run & now the pump is getting weaker to the point where it can no longer do that. Take the gas cap off & see if the stall condition goes away.
