Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (UtahYork, Joe H), 45 guests, and 1 robot.
Topics128,018
Posts1,055,260
Members48,417
#526592 04/09/2009 5:51 PM
I would like to find a gasket set for my '53,6100,two speed
rear axle.Any sugestions?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
1 Offline
Yea I got two.
Get some gasket material and make it
or silicone.
I know that's not what your looking for but I doubt if anyone makes it, at least I haven't seen it
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
3B Offline
Hy PapaJ, Fel-Pro p/n RDS5050, 10 holes for the cover, p/n RDS11855, 10 hole for between the diff. and housing, that's if it has the rear end it left the factory with. If you could post some dimensions and number of holes I could possibly confirm, hope that helps.
Big Bolt Forum Co-moderator
That gasket has come before... let me do a search and get back.
1948 Chevy 2-Ton
I think this was the post I was looking for:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=5&Number=439777&Searchpage=1&Main=60670&Words=%26quot%3B5049%26quot%3B&topic=0&Search=true#Post439777
1948 Chevy 2-Ton
What I really need is gaskets for the side diffs.
1953 Chevy Two-Ton
We have been using RTV instead of gaskets for many years on our over the road trucks. Eaton and Meritor uses it from the factory. For a quick fix 30 to 50 years ago, we used to loosen the diff a little, wrap cotton string around the whole thing 4 or 5 times and retighten the diff. It would usually hold longer than gaskets.
3B Offline
Hy PapaJ if you're looking for the axle flange gaskets, measure the outside diameter of your axle, and the number of bolts retaining them, and post that info here and I can figure it out for you, or you could just use silicone.
It could be splitter for the two speed that is leaking,Haven't
had a chance to clean it off yet.
1953 Chevy Two-Ton
