| | | Forums66 Topics128,206 Posts1,057,433 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 4 New Guy | | New Guy Joined: Apr 2009 Posts: 4 | I have a 52 3/4 ton and was wondering what is the easiest way to get 3.73 gear ratio in the rear end AND update to better brakes? Switch for a Chevelle axel complete with the rear brakes? Is that even possible? Will I need to update the front with IFS and disc. If so with what product? I want "safe" daily drivability. But also want it without dropping a ton of cash. ( I know that that last one's a pipe dream) I'm also willing to forego a little originality. Anyone? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The only way to get gears like that is to swap rears. You don't have to swap the front too, but a swap is about the only way to get away from the 8-lug hubs.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | A rearend swap is what you'll have to do. You could try an S-10 rearend. It's perfectly o.k. for the 6 cylinder, but if you plan on a nasty V-8 I would look for something a littlle beefier. A rear of an 80's era 1/2 ton or van should more that suffice. For the front, that's another issue. There's no brake upgrades available for the 3/4 ton. You could do a whole IFS swap or have some bushings installed into your axle and swap your spindles for some 1/2 tons. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | For the front axle you can do what I did to my 52 3/4 ton. I removed the 3/4 ton axle and swapped in a 1/2 ton axle. Was the easiest swap I ever did. Would have gone faster if the U-bolts weren't rusted to where I couldn't remove the nuts. I ended up taking a cutoff wheel and cutting the u-botls off and ordering new ones. When the U-bolts came in, within 5 minutes I had the 1/2 ton axle bolted in. I am still using the 3/4 steering arms which required no modifications. I installed a 1/2 ton 5 lug disc brake kit, as well as a cpp power steering kit that mounts a GM steering box on the outside of the frame rail.
The truck isn't going to used for hauling heavy loads but the front would basically be rated as a 1/2 ton. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | My FLAPS had the correct square U-bolts I needed when I was working with the front springs on a 57 I had a few years ago.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
