| | | Forums66 Topics128,288 Posts1,058,579 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | I have a 2nd series '55 and every time I remove the gas cap it makes a sound like I'm relieving a vacuum. I always thought it was normal, but now it keeps stalling and will only idle. The fuel filter is clean. It will idle perfect, but as soon as I hit the gas it stumbles. If I shut it off for a minute or two it's ok for a little while. Should it actually have a vented gas cap on it? It has always made that noise and I have driven it 2 hours at a crack with no troubles so I don't know why all of a sudden I'm having trouble.
Help please! | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | yes the cap should be a vented one.As the fuel pump removes fuel from the tank, an equal amount of air must replace it,or a vacuum is created.I think the amount of fuel in the tank would affect the drivability.The fuller the tank,the sooner a vacuum is created | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | An addendum to BC52's post. One possible reason you are now having difficulty where you didn't in the past could be that you had a strong enough fuel pump to pull enough air into the tank past the unvented cap to allow the engine to run & now the pump is getting weaker to the point where it can no longer do that. Take the gas cap off & see if the stall condition goes away.
