7 members (klhansen, carbking, Otto Skorzeny, Ponchogl, Peggy M, HandyAndy, Hotrod Lincoln),
174
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,034 Posts1,055,541 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52853 11/27/2005 1:11 AM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I have a 57 buick, and to set the time on that I put the timing light on the harmonic balancer and line up the mark on it with a mark on a piece of metal on the block. My 235 engine has a set of marks on the flywheel. One is a triangle, there is a small circle, and I believe 3 straight marks. I assume this is used to set the time, using the pointer just back of the starter. QUESTION: What in the world are all those marks for, and which one do I use to set the time. I need to put the distributor back in, and I need to know when the number one cylinder is at top dead center. How to I tell when that happens. Thanks for your help. Allen | | |
#52854 11/27/2005 1:31 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the ball is all that counts, never seen the others
Bill | | |
#52855 11/27/2005 1:41 AM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Bill. Thanks for the quick reply. The Circle is on one side, there are 3 straight lines, and then a triangle on the other. Assuming the circle is all that matters, how do I tell when the number one cylinder is at top dead center? As nearly as I can tell from the numbers on the motor, the engine was built in 1961, and was originally installed in a series 3100 pickup. But, I don't think that makes any difference. Allen | | |
#52856 11/27/2005 2:40 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no, they're all the same - the circle should be a little ball stuck to the flywheel - the lines may be to help w/ advance or retard, but correct timing is when the ball is visible at the pointer w/ a timing light - to find TDC remove #1 plug, put a finger over the hole, and crank until you feel compression then go just enuff further to line the ball up - if you've got the valve cover off, crank until #1 intake is closed, then a bit further to line up the ball
Bill | | |
#52857 11/27/2005 2:04 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Bill: Thanks again. I don't have a ball on the flywheel, but I will assume the circle is the same thing and go with that. I think 61 or 62 was the last year this engine was produced, so maybe by the time they built the one I have, they changed the system a little. I'm sure a shop manual from the proper year would tell me for certain, but I don't want to buy one just for that one piece of info. Allen | | |
#52858 11/28/2005 4:16 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | According to Motors Truck Repair Manual, 19th Edition, '59 and older engines time to the ball. 1960-1962 engines time "First short radial mark clockwise from timing ball." | | |
#52859 11/28/2005 2:55 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Cletis: Thanks for the info. That will help. All this talk about a ball has me confused. Did some of the flywheels actually have a ball on them? Mine has a circle, but there is no ball. Allen | | |
#52860 11/28/2005 4:49 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, earlier ones had a ball only. Yours is a later one. | | |
#52861 11/28/2005 4:56 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | if you can, would you show a pix of the ball. thanks Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#52862 11/28/2005 8:10 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Fred.... It looks just like a beebee,imbedded in the face of the flywheel. Steve sr | | |
#52863 11/28/2005 9:34 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | thanks, I had a hard enough time seeing the small screws holding my electronic module in my dist,, you can actually see this ball/bb from the top side of the engine? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#52864 11/29/2005 8:50 AM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Guys: Thanks for all the help. I think I have the distributor in correctly. I'm now having another problem. Check out my post under the timing marks thread. It probably should have been in the electrical section. Thanks Allen | | |
#52865 11/29/2005 1:08 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | The triangle (sometimes a square or diamond)is TDC, the ball is the timing mark for a stock engine.
What is a BB :confused: (sorry I´m german:D)
Frank | | |
#52866 11/29/2005 1:57 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Frank: A BB is a small round piece of lead or steel that looks like a very small ball bearing. Everything has changed since I was young just after the big bang, but back then we used them in our toy rifles. The rifles were spring loaded, and whey you worked the lever it would load one BB in the chamber so you could fire it. About the only thing the gun was good for was to accidentaly shoot some one in the eye, but we thought they were fun. In this day of political correctness and over reaction to everything I doubt you can still buy the toy guns. Thanks for the information about the triangle. It has been a long running mystery. Allen | | |
#52867 12/01/2005 2:52 AM | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | I just went through this with the '55 235 I put into my 1940 GMC. I used the '41-'54 6volt type flywheel. I tried timing to the BB, but it was off. Then a buddy told me his '51 manual said to use the triangle. Since this is a '51 era flywheel I tried using the triangle and it timed perfectly. It then fired right up. Checked it with timing light and it was right on.
Steve | | |
#52868 12/04/2005 3:54 PM | Joined: Sep 2005 Posts: 16 Junior Member | | Junior Member Joined: Sep 2005 Posts: 16 | I believe the BB is .177 caliber or 4.4 mm | | |
#52869 12/04/2005 4:29 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | BB was a name for a specific shogun ammo pellet/bead size (lead or zinc/copper-coated steel). Shotgun ammo pellet/bead sizes "Originally, the first BB guns had a bore size of approximately 0.180 inches. This is close to the shotgun pellet size BB, which falls in between shot size B and size BBB. Hence, little boys used lead BB shot in their guns. Later, Daisy standardized lead shot to 0.175 inches and called it air rifle shot." | | |
#52870 12/05/2005 1:34 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Steve: You are exactly right. I used the triangle and it fired right off. Allen | | |
