5 members (klhansen, HandyAndy, Hanks custodian, Hugh63c10, dt235sd), 66 guests, and 1 robot.
Topics128,092
Posts1,056,043
Members48,433
#527746 04/13/2009 3:03 AM
Hello,
Just wondering how the dome light in a 41 chevy truck turned on.
Was there a seperate switch or was it automatically when the door opened?
Switch on the dome light, I belive.
1949 Chevy 6400
1931 Chevy Firetruck
definitely wasn't door operated
I just reviewed my wiring diagram and it shows it going to the light switch.
It goes from the light switch to a 2 post terminal block and than to the light.
Anyone have any ideas where this two post terminal is?
Thanks!
It's a two way switch that is supposed to be under the dash to the left of the ashtray. Look at page 7. I think one direction to the instrument panel the other way to the dome light. Middle position= off...I think.
If one wanted door poppers for interior lights it is relative easy to install. Just check with NAPA for the right ones, drill and plug them in. I use grounded poppers and a $5.00 relay as the AD interior light is grounded and must receive a positive charge to light up.
~Jim
Dome Light……What dome light. According to the owner’s manual there wasn’t one. That switch near the ashtray under the dash is a 3 position switch powered when the head lights are on. Left is the dash gauge lights, center is no lights, and right is a light behind those openings in the center of the dash to sorta illuminated the ignition, choke, and throttle plus enough to read a map
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Your 41 might not have had a dome light but the AD trucks do. They are found directly above the rear window and are activated by the headlight switch. My point I'll repeat; if someone wanted spring loaded switches that activate this light when doors are opened it is easy to do. dang
~Jim
