5 members (Phak1, BC59, MickeyP, Oldcaliforniakid, Gdads51), 85 guests, and 2 robots.
Topics128,049
Posts1,055,667
Does anyone have these numbers by any chance, or do you know where i can get them.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
i only see the 250 starting in 1966 it is 46n plug gap .035,point gap .019 ,dwell31-34,6 degree's timing btdc ,500rpm std trans ,150 lbs compression ,3-4 1/2 lbs fuel pump pressure .this is for std truck non air injection reactor system . this is out of a 1960-1970 motor's truck repair manual
my 250 is out of a boat, the guy i got it from used the 67 chevy bisycane as a reference for the motor
