1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Hello, Just wondering how the dome light in a 41 chevy truck turned on. Was there a seperate switch or was it automatically when the door opened? Thanks | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Switch on the dome light, I belive. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | definitely wasn't door operated
Bill | | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | I just reviewed my wiring diagram and it shows it going to the light switch. It goes from the light switch to a 2 post terminal block and than to the light. Anyone have any ideas where this two post terminal is? Thanks! | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | It's a two way switch that is supposed to be under the dash to the left of the ashtray. Look at page 7. I think one direction to the instrument panel the other way to the dome light. Middle position= off...I think.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If one wanted door poppers for interior lights it is relative easy to install. Just check with NAPA for the right ones, drill and plug them in. I use grounded poppers and a $5.00 relay as the AD interior light is grounded and must receive a positive charge to light up.
~Jim
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Dome Light……What dome light. According to the owner’s manual there wasn’t one. That switch near the ashtray under the dash is a 3 position switch powered when the head lights are on. Left is the dash gauge lights, center is no lights, and right is a light behind those openings in the center of the dash to sorta illuminated the ignition, choke, and throttle plus enough to read a map | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Your 41 might not have had a dome light but the AD trucks do. They are found directly above the rear window and are activated by the headlight switch. My point I'll repeat; if someone wanted spring loaded switches that activate this light when doors are opened it is easy to do.
~Jim
