0 members (),
62
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | I was trying to see where the ID numbers are for my '34 half ton---from the tech tips it seems chevy didn't put numbers on the frame then. Is that true? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that's right, numbers stamped in the frame didn't start until the TF years - not sure about the 30's, but the 40-46 has a tag on the cowl under the hood
Bill | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Davy, There are two possibilities-- On the firewall(passenger side) or on the rear of the passenger side doorjam. On the 34 I believe it is the doorjam-- Glenn | | |
