| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Where does it go? I see this in the catalogues, I have a column shifter, but can't imagine where exactly it might go. As a refresher, this is the black, accordian-type rubber boot that's about an inch long, an inch wide. Thanks. | | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | P.S. I scoured the forum via the SEARCH feature, and couldn't find anything...repeat "anything" about a column shifter boot. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's the dust seal on the top of the sifter box on the column under the hood, prolly never mentioned here  Bill | | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | ahhhh, under the hood. I'll try it...thanks. | | |
