| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52697 11/22/2005 7:08 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | on the zenith carb, on the bottom rim, there's a small brass slotted screw with a hole in it. at least there's supposed to be. mine's missing. what does it do? i notice the carb sometimes idles too fast, but will slow down if i blip the throttle. could this be the cause?
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#52698 11/23/2005 2:35 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | well, since i got no takers yet, i'll add more info to possibly help out. with the engine off, the throttle comes back to the correct idle position every time. but, with the engine running, it won't return without the blip, but you can force it back down easily. like the vacuum going through the throat is somehow strong enough to hold the plate open despite the big spring on the linkage connected to the bottom of the oil pan! maybe i gotta get a bigger spring?
#52699 11/23/2005 5:44 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've got a 37 with a 261 and I believe we both have a mechanical bell crank set up for the throttle. I have had trouble for years getting mine to work correctly. The problem is partially due to running two carbs with a partially homemade linkage set up. The only solution I ever found was a bigger spring, too! Still I, too, had to "blip" the gas pedal to slow the idle. I finally rebuilt the throttle linkage using ball joint ends at the bellcrank and the carbs along with a bolt through an eyebolt at the end of the of the throttle shaft where it attaches to the bell crank. Now I have a smooth operating throttle with a normal off the shelf throttle spring, but I had to reinvent the stock one to get it to work right. A rework may be in your future. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#52700 11/24/2005 4:11 AM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | The "blip" you have to do is a result of the butterfly shaft being worn. Only way to fix it is to take the shaft out, drill and install a bushing in the bore where the shaft rides. | | |
#52701 11/24/2005 6:14 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | okay, sounds great. i attempted to remove the 2 screws in the butterfly and them both stripped right off. i drilled them to get the shaft out. now what do i do?
