5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
#525891 04/07/2009 11:47 PM
I did a search on both fuel tank and gas tank removal but it didn't address my question. I loosened the two top straps on the tank and it didn't budge. Are there lower bolts I'm not seeing under the cab? The filler neck has also been removed.
Dan B. #525897 04/08/2009 12:04 AM
Did you disconnect the gas line from the bottom of the tank?
Larry Hayes
Charlottesville, VA
48 3600 Flat Bed
49 6400 Grain Dump
48 Allis Chalmers G
Larry #525901 04/08/2009 12:23 AM
I would say that it is just stuck. I would give it a good bang using both hands at the top.
1951 1 Ton Completed
I had to learn too. As mentioned above, don't forget to disconnect the gas line!! Then you'll have to remove the brass stopcock in order for the rigid gas pipe to pull through the hole in the floor. Should come out easily once you've done the obvious.
Spot
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
