2 members (klhansen, 1 invisible),
88
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | I am about to swap out my original 3spd to a 4 spd. The 4spd is out of a late model and is shorter than my stock 3spd. My main consern is the tails. Can I swap the tails on the two so I don't have to lengthen my drive shaft? If anybody knows, i'd appreciate the help. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | from input to output on any trans is specific to that trans, so not likely you could mix n match .... to take care of the driveshaft you might check the length of the one that was with the trans, could luck out, the spline on the front yoke will be different than your 65 anyway so you'll have work to do on the shaft regardless
Bill | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Many Chevrolet transmissions have both long and short tailshafts. They are readily interchangeable, if you use all the same internal parts. This does not present any problems with using the shorter driveshaft with the longer tailshaft. I have done this interchange several times. | | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | Thanks guys. After some talking and thinking I came to the conclusion to just lengthen the drive shaft. Evidently my dad has a lot of experience in the matter. You never know what a parent use to do back in "their day". Doesn't hurt that he's been a certified welder for over thirty years either. Thank anyway. | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | "The 4spd is out of a late model"
Do you mean a late model truck? If the 4 spd is from a '68 or newer truck it will be a SM465. If you didn't get it with the trans, you will need the bellhousing with larger hole for the bearing retainer.
'67 GMC 3/4 292 4spd
