8 members (Oldpickupman, 41 chev, 51sub, Gdads51, Charles in CA, Nick in Manitou, TUTS 59, 1 invisible),
103
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | I'm having a problem with the brakes in my 51 chevy 2 ton 6100SW. After adding fluid and pumping away the pedal will become hard and seem to be okay. But only after pumping the pedal several times. First 3-4 pumps and it goes to the floor. I'm reading that I must bleed the system first hydrovac, with a pressurized bleeder tank with a minimum of 20 psi. Does the bleeding have to be under pressure? and if so, where do I get a tank or have it done? Thanks for your help with this one! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The Motive Power Bleeder is a reasonably priced pressure bleeder. Follow the directions in the Shop Manual (the sequence for bleeding the hydro-vac and the various wheel cylinders must be followed). Some people have reported making their own pressure bleeder (I bought the Motive unit for use on my 2-ton COE and it works well). | | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | Thanks for the info but which one would you recommend to buy. There seems to be several types and I would like the same results that you have had. Did you have to make any modifications to the pressure bleeder? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Sorry, I see they prevented my direct link to the correct model: Classic American and Marine Trailer Bleeder 0102
By the way, search the Internet for best price with shipping.
I made no modifications.
| | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | Thank you much for quick reply. Your info was right one 0102 was ordered today. Who ever said a NY would never help a RED SOX?  | | |
