7 members (TUTS 59, LAROKE, Donf, tclederman, 3 invisible), 68 guests, and 5 robots.
Topics128,181
Posts1,057,177
Members48,465
Hey guys,
Last fall I put new wheels and tires on my '51 Chevy 3604. When I turn the wheels to about 45 degrees, the two front wheels start rubbing. These wheels are a tight fit and my installer put weights on the inside of the wheel as well as outside. I think it is rubbing on them. Where can I find an 8-lug wheels spacer? I see them for 6-lug but not for 8-lug. I don't need much additional space but a little will make the difference. Thanks for your help, Jeff.
The ones that I have seen for sale are aluminum. I have seen them in Ebay stores. I had my 8 lug wheels balanced with tape weights used on the inside.
1951 1 Ton Completed
